SOLVED RSS Not Working
Subject: RSS Not Working
hi @ll
I changed hosting and from that moment on RSS feed stop working.
I´ve checked the server settings and all xml is present and enabled.
Incoming feeds got the message: Unable to open XML feed ( the feed adress is a valid one)
Outgoing feeds got this msg: no valid rss feed has been configured ( that worked aswell before. URL has been changed, so this is´nt the problem)
Got to say BTW that i downloaded the site fromn the all server and uploaded like it was ( only changed config) and updated the DB to new domain.
Same problem with a fresh install on the same server. And a friend of mine got an Icy site with the same hoster and the same problem
question. could it be a ht.access problem or a php.ini problem
I realy got no idea how to set up the php.ini file nor the access file.
Anybody can give a hand pls.
Subject: Re: RSS Not Working
The problem seems to be your hosting has disabled fopen PHP function for external websites. I had the same problem some weeks ago, and I could not resolve it.
So let's start trying... Add this line in the beginning of your .htaccess:
php_flag allow_url_fopen on
If it doesn't work, just do this
Open includes/xs_news.php
Find
if (($fp = @fopen($xml_feed, 'r')))
In that line, delete the @
Then, go to where RSS feeds should be displayed and just let me know the error that appears. (after pasting here the error unmake the change so the error will stop appearing ;) )
Greets!
that´s the message
Here´s a pic of the server config
php_info
It look´s like the server is loading my ini file but theres no changes
so probably i got something wrong in there
Have you tried htaccess fix?
If you haven't, please do it. If you had:
Try to add this to your htaccess instead of the line I told you before. Add it on the fist line:
php_flag allow_url_include on
If this doesn't work just try to find allow_url_include in your php.ini file and replace off or 0 with on. The problem is that I really don't know where this file is located, and if you can modify it.
it seems that theres no way to access that ini file.
but the server reads the ini file located in my root.
so there must be a possibility to enable the functions via root ini file.
problem is , i don´t now anything about ini files.
and probably it want work if i use the ini file from mi local server
Ok, it seems you are not understanding me ;)
.htaccess file is a way to configure a lot of things of a UNIX server. One of this things it can configure is PHP (overriding php.ini values). To configure a PHP setting you have to write php_flag, and then the setting you want to configure, followed by the value of the function.
So what I'm trying to say is that php.ini modification is inaccessible in most of the servers, but .htaccess file has the ability to modify some configurations if the UNIX server is configured to allow it.
Then, just open the file named .htaccess located in your forum root with a plain text editor such as Notepad, Wordpad or Dreamweaver and add a first line with this content:
(Just an observation: putting a # before a line in htaccess makes the engine to ignore it, it is just as PHP's //)
Greets!
tried that.
not working
throughs an 500 error
could it be that the htaccess like it comes in Icy is incompatible with the Zend2 the server uses ?
Edit: nope thats crap. what i need is to enable the fopen. I allready send a msg to the hoster.
Or is there any chance to do an pseudo fopen?
Meanwhile you can try to create a php.ini in your root folder and paste this text:
allow_url_include = On
But I think the solution will be to contact the hosting and see what they can do for you, because if htaccess doesn't work...
php.ini doesn´t work aswell.
tried anything now.
i think i´ll keep waiting for the hoster.
I´ve asked them to enable fopen and url_include.
so lets see how long they take to do it
But what really drives me crazy, is the point that my wife has got a WP site on the same server and feedburner and flicker rss are running without any problems.
Subject: Re: [SOLVED] RSS Not Working
Problem fixed with ini file.
I probably did something wrong before. so i went to Lopalongs How To and just copied the ini code from were and created a new ini file for my server. It runs without problems now
Generation Time: 0.2314s (PHP: 9% SQL: 91%)
