Problem With Links HTML
Subject: Problem With Links HTML
I have activated the option: "Links HTML por guest desactivated", in the portal works good but in the forum, when I logged on and entered a post with a link html appear this:
dibujo
That is, I'm connected and the links do not appear.
What I do?
PD: In lang_main.php I have edited Links_For_Guest and have put the original message and I still receive "You must be registered"
Subject: Re: Problem With Links HTML
try switching precompiled posts of
you find that in ACP/Icy Phoenix/ messages and posting
Generation Time: 0.3036s (PHP: 5% SQL: 95%)
