Hello. We especially beforehand forgive my bad English, since unknowingly have to use the translator.
I wanted to comment that after the update I have had and still have many flaws that I can not fix ignorance.
Tube failure of the pictures in the albums that I change by hand touch, tube failure resolved with the smiles that you published the post but this only solves the problem in fast response, not normal response.
but those are my minor problems.
Right now I'm in the situation that I do not work:
* the watermark, even though the asset does not work.
* The header sitelogo_small, much as the exchange for another at the ftp there is no substitute for putting.
* And insatlacion of mods, even though modified to install these mods, do not work, do not throw any error, but do not work.
no longer do.
had thought about trying to do the update from 2.7 to the 3 again to see if that solves the problem.
do you think???
greetings and thanks
Borgo San Michele
