Post CODE And MOD TEMPLATE In Bbcode - How To Make It Real?
Hello again!
I got a little Problem. I want to make the "code" "/code" in my posting editor because i got only the normal "code"-function.
Hope you understand what i mean?
Example like this:
test
And i want this function:
OPEN
test
testings
So how i can do this?
I found no explanation for this. -.-"
GhostsearcherSend private message
Post Re: CODE And MOD TEMPLATE In Bbcode - How To Make It Real?
Oops, i guess i have to say i'm sorry. This seems to be a normal bbcode from phpbb3.
It is because, i never used subsilver2 nor prosilver and i could not find this with the implemented BBcodeBox3.
Well, i'm just a very big fan of Black Pearl.
Post Re: [SOLVED] CODE And MOD TEMPLATE In Bbcode - How To Make It Real?
So you solved your issue?
I think you can create a custom BBCode in ACP to get what you need.
Nope, not solved.
If i knew how i would implement the bbcode. But in this case.... I let it be ^^
If you go to ACP => POSTING => BBCODES you can customize BBCODES.
Add a new one and try this:
BBCode Usage:
[modfile={SIMPLETEXT1}]{TEXT1}[/modfile]{TEXT2}
HTML Replacement:
OPEN <strong>{SIMPLETEXT1}</strong><br />
<br />
FIND:<br />
<div class="codetitle"><b>{L_CODE}:</b></div><div class="codecontent">{TEXT1}</div><br />
<br />
REPLACE WITH:<br />
<div class="codetitle"><b>{L_CODE}:</b></div><div class="codecontent">{TEXT2}</div><br />
<br />
Then flag Display on posting page.
_________
You can then use something like this:
[modfile=forum.php]Test[/modfile]Testing
You need to perform some tweaking of course... this is just a basic demo.
