Alternating Random Background Images
Subject: Alternating Random Background Images
I am using Rainbow Pearl and Black Pearl in my new forum but would like to alternate the background image in the header. I have tried adapting what I have read to suit but without success.
Is this even possible?
Thank you
Subject: Re: Alternating Random Background Images
hi i use black pearl, can you clarify what you want to do exactly?
Sorry. I guess I wasn't clear.
I am using a background image in the header of my site. Check it out here.
I would like to alternate that image. How do I do it?
thanks
I answered here:
http://www.phpbb.com/community/view...72585#p11772585
Mighty Gorgon wrote:
You should alter top_header.png in stylesheet.css with the dynamically generated image.
  1. #top_logo{
  2. border-width: 0px 0px 0px 0px;
  3. margin: 0px 0px 0px 0px;
  4. padding: 0px 0px 0px 0px;
  5. background: url('./images/top_header.png') repeat;
  6. height: 150px;
You need a dynamic image and there are several ways for doing that.
Usually you should code a php files which generate the images and then use directly the PHP files (with correct headers) or use an htaccess rule to redirect a PNG call to the PHP files.
So in a nutshell, here is a demo for a dynamic PHP image (supposing you have the JPG files listed in the array):
  1. <?php
  2.
  3. $img_array = array('bkg_01.jpg', 'bkg_02.jpg', 'bkg_03.jpg', 'bkg_04.jpg', 'bkg_05.jpg', 'bkg_06.jpg', 'bkg_07.jpg', 'bkg_08.jpg', 'bkg_09.jpg', 'bkg_10.jpg', 'bkg_11.jpg', 'bkg_12.jpg', 'bkg_13.jpg', 'bkg_14.jpg', 'bkg_15.jpg');
  4.
  5. $img_rnd = rand(0, sizeof($img_array) - 1);
  6.
  7. header('Content-type: image/jpg');
  8. header('Content-Disposition: filename=' . $img_array[$img_rnd]);
  9. readfile($img_array[$img_rnd]);
  10.
  11. ?>
Suppose you call this PHP file my_bg.php then you can use this file directly in the CSS (or use htaccess to redirect that file using a JPG call instead).
Generation Time: 0.0748s (PHP: 37% SQL: 63%)
