Problem With Google Analytics
Subject: Problem With Google Analytics
Hello everyone,
I have a problem with google analytics.
From ACP i placed the code copied from goolge in the textbox:
var gaJsHost = (("https:" == document.location.protocol) ? "h**ps://ssl." : "h**p://***.");
and I like prints in the html code:
<script type=\"text/javascript\">
var gaJsHost = ((\ "https: \" == document.location.protocol)? \ "https: / / ssl. \": \ "h**p://***. \"); .....
Can someone help me?
Tnx :)
Subject: Re: Problem With Google Analytics
this looks like an issue with php magic_quotes, there are quite a few php programs that do not work with magic quotes enabled.
I had the same problem... but I don't know how I fixed it.
A workaround is:
OPEN templates\default\overall_footer.tpl
{GOOGLE_ANALYTICS}
Inser the code you get from Google Analytics
Clean cache after it ;-)
Same problem here.
I fixed it by adding the code to the overall_header.
But if IP have a section to add this code I think this might be a bug.
This should have been fixed in latest dev release.
Generation Time: 0.067s (PHP: 25% SQL: 75%)
