Wordgraph Bug?
Subject: Wordgraph Bug?
Hi, I have updated Icy to the latest and upload my current testing forum to http://www.sarakin.byethost2.com/icy3 and it seems there's a problem with the special chars in Wordgraph. Is this a known issue? Any solution?
Subject: Re: Wordgraph Bug?
I can't see wordgraph content on your site.
Can you enable it for guest or attach a screenshot?
No, you can't because it's a free testing site with limited SQL space and my search tables are so big. If you want, I'll update again next week but truncating the posts table in order to save space and to making you able to see the issue. Anyway and meanwhile, I tell you I guess the trouble is that the updating pack doesn't convert well the search tables to UTF8, which are still in latin1 and this is what makes troubles in a UTF8 database with spanish special chars like "á", "é", etc. In local I solved the issue copying the table from the old Icy database, so it's still in latin1, but it shows well.
Thanks for your attention, MG.
Well... you didn't mention it was a conversion and not a clean install, so the problem could not be just Wordgraph, but charset encoding in DB which is a different thing.
In any case further details are needed to understand what the problem is.
I don't want to flame you but...
Sarakin wrote: [View Post]
Ok, write them here and I'll be glad to help with this bug. Anyway, next week I'll upgrade again in order to make you able with your own eyes :roll:
Generation Time: 0.1022s (PHP: 16% SQL: 84%)
