SOLVED Two Logo's In Header - Milky Way Red
Subject: Two Logo's In Header - Milky Way Red
I have 2 unique logo's I want to place on the header background, both should have a href for the specific logo's.
I have been trying to add both, without any luck.
Please can you help
Subject: Re: Two Logo's In Header - Milky Way Red
hi IronHide,
it's quite hard to say anything when there's this little info, any example link or screenies of your try, maybe even some code you tried etc etc would help to get a picture of what you are talking about :wink:
If you could post the header code here. and lets say the path of the images you want to use + the URL you want them to link to
hi
here is the latest header code I am trying. hope this helps ..........
<td align="left" valign="middle"><a href="h**p://***.rocamracing.co.za"><img src=".styles/milky_way_red/theme/images/rocam.jpg" height="100" width="300"></a></td>
<td align="right" valign="middle"><a href="h**p://***.cvhracing.co.za"><img src=".styles/milky_way_cvh/theme/images/cvh.jpg" height="100" width="300"></a></td>
<td align="center" valign="middle"><h1></h1><span class="gen"></span></td>
<td align="right" valign="top">&nbsp;</td>
<td align="left" valign="middle"><a href="http://www.rocamracing.co.za"><img src=".styles/milky_way_red/theme/images/rocam.jpg" height="100" width="300"></a></td>
Hm.
Looks like your image path is“nt correct.
try with this one :
<td align="left" valign="middle"><a href="http://www.rocamracing.co.za"><img src="../styles/milky_way_red/theme/images/rocam.jpg" height="100" width="300"></a></td>
have figured it out already thanks ... working perfectly now
Generation Time: 0.0902s (PHP: 31% SQL: 69%)
