Re: Forum Category Problem !
I guess that's because of forum compression. If you go to ACP -> Configuration -> Icy Phoenix -> Forum and select medium compression level it should be resolved.
If not, check that setting on your UserCP (Profile -> Forum)
The time now is Mon 25 Aug, 2025 02:33 • All times are UTC + 1 Hour [DST enabled]
