[Solved] My FTR MOD Doesn't Work
Subject: [Solved] My FTR MOD Doesn't Work
:cry: why! why! :cry: xDDD.
I have activate and tested, but nothing happens. I have delete all users have to read, I have try al combinations of it but not working...
Any ideas?
Thanks!
PD: There is another option dont know where that allow you to disable the Force To Read
Subject: Re: [Solved] My FTR MOD Doesn't Work
Have you choosen the topic that must be FTR?
Yes Zucker, I solved this 10 minutes after. I configure all but doesnt work.
I was doing maintenance operations and I found aun of FTR menu another option that allow you to disable FTR.
Thanks anyway!
ok tiolalu,
greets
Generation Time: 0.267s (PHP: 6% SQL: 94%)
