Post Problem With "Gender" Field.
Whether I select yes or no to "Force users to submit their gender" they are forced to submit it ("Not specified" is grey and unselectable)
Is it a bug? What to I have to check?
Post Re: Problem With "Gender" Field.
If they are force to submit... they have to choose one option, that's because "not especified" is gray
Zuker wrote: [View Post]
Yes. But my problem is that if I want them to be free to choose to not specify the gender (so I select "no" to "Force users submit gender") the "not specified" button still remains gray.
Clear your browse cache and the cache of the foro and try again to see the page .
My 2 IP Forums:
tiolalu wrote: [View Post]
Doesn't work
I can choose whatever I want, so It's working for me .
My 2 IP Forums:
If they leave "not specified" as default without touching the gender, it remains not specified, but if they want to pass from a male/female status to a not specified status the can't... and it goes without saying that it's right in this way, if you have selected the male/female gender, why should you want not to specify it later?
z3d0Send private messageVisit poster's website
z3d0 wrote: [View Post]
Well, that really does make sense
I manage a teens' forum, so sometimes they come out with this kind of request I try to satisfy even if sometimes they appear to be senseless
If some of you could tell me how to modify the mod, I would appreciate. Otherwise, if this is the way the mod is meant to work, there is no problem
