If i recharge the forum, sometimes, appear this error:
Fatal error: Allowed memory size of 16777216 bytes exhausted (tried to allocate 491520 bytes) in /home/tecnicas/public_html/includes/template.php(935) : eval()'d code on line 547
url: http://www.tecnicasfotograficas.com/
I think if due to album block, Anyone who has this error?
Sorry i dont planing to update the forum until the next version...
Problem With Album Block In 1.2.0.27c, Allowed Memory Size...
Subject: Re: Problem With Album Block In 1.2.0.27c, Allowed Memory Size...
Version 1.3 is much more efficient in managing memory.
If you don't want to update (and I strongly advice to!) you should try to disable some CMS blocks.
Hello Mighty Gorgon,
I am waiting to the next version..... :mrgreen:
At the moment i disable album block.
Thanks you.
Thanks you.
There is no planned release for the new version.
There is still a lot of work to be completed before.
Thanks you... i am very happy with 1.2.0.27c... but i supose that i have to update ASAP.
Generation Time: 0.0853s (PHP: 19% SQL: 81%)
