SOLVED Cache Problem :(
Subject: Cache Problem :(
i have a huge problem with my cahce folder, i deleted it accidentaly but that wasnt a prob cuz i had a backup.
Now the restored cache folder doest work and i get lots of sql faults ,i cant even login .
its realy messed up.
EDIT
Sry for my disperate action, i have solved this by apllying 777 cmod permisions to cache.
PS: Delete this post.
Subject: Re: Cache Problem :(
If you really want to i will delete it but do nt you think this post can help others? because it contains your fix! :mryellow:
Generation Time: 0.086s (PHP: 18% SQL: 82%)
