SOLVED Forum Ranks
Subject: Forum Ranks
I edited the forum ranks, on the forum and assigned them to different groups and users.
The title haven't changed. It remains the same as the old one, same with image.
This applies to all the default ranks which i changed.
New ranks doesn't display at all :/
Is this a bug or?
Subject: Re: Forum Ranks
Hi there
Have you cleared/purged your board's cache and also your browser?
i have the same problem.
it's a shame because i really like that 'village idiot' rank, it's totally funny LOL
Hi deejay,
same question for you:
Hi there
Hi deejay,
Hi there
ha that was the problem then.
thank you!
but i still have another problem. this time about the custom profile field. i think i posted a new topic about this.
if users key in letters only, it works just fine. but if users key in numbers only, then it's messed up because somehow it change automatically
userkey = password??
no Spydie
key in = type :wink:
Deejay you have indeed asked this question here:
http://www.icyphoenix.com/viewtopic.php?f=2&t=7600
please wait for a reply there to avoid confusion, thanks
Edit: I will mark this one solved :wink:
Generation Time: 1.3948s (PHP: 2% SQL: 98%)
