Re: In Prosilver_ip, Forum_nor_ar_read.gif Images Location
Example:
Change this:
$images['forum_nor_unread'] = $current_template_buttons . 'forum_nor_unread.' . $images_extension . $img_fade;
To:
$images['forum_nor_unread'] = $current_template_buttons . 'forum_nor_unread.gif' . $img_fade;
But that will require all of your forum_nor_unread buttons for every theme to be .gif
Better try this:
Open prosilver_ip/prosilver_ip.cfg
Find:
include(IP_ROOT_PATH . 'templates/default/default.cfg');
After ADD:
$images['forum_nor_read'] = $current_template_buttons . 'forum_nor_read.' . $images_extension . $img_fade;
$images['forum_nor_locked_read'] = $current_template_buttons . 'forum_nor_locked_read.' . $images_extension . $img_fade;
$images['forum_nor_locked_unread'] = $current_template_buttons . 'forum_nor_locked_read.' . $images_extension . $img_fade;
$images['forum_sub_read'] = $current_template_buttons . 'forum_sub_read.' . $images_extension . $img_fade;
$images['forum_sub_unread'] = $current_template_buttons . 'forum_sub_unread.' . $images_extension . $img_fade;
$images['forum_sub_locked_read'] = $current_template_buttons . 'forum_nor_locked_read.' . $images_extension . $img_fade;
$images['forum_sub_locked_unread'] = $current_template_buttons . 'forum_nor_locked_read.' . $images_extension . $img_fade;
$images['forum_link'] = $current_template_buttons . 'forum_link.' . $images_extension . $img_fade;
$images['forum_nor_ar'] = $current_template_buttons . 'forum_nor_ar_read.' . $images_extension . $img_fade;
$images['forum_sub_ar'] = $current_template_buttons . 'forum_sub_ar_read.' . $images_extension . $img_fade;
And change them there!
Also in prosilver_ip.cfg is this.
$buttons_extension = in_array($color, $png_buttons_colors) ? 'png' : 'gif';
Try swapping 'png' : 'gif' to 'gif' : 'png' so that you possibly don't have to edit the strings.
But you will still need to copy the $images* that you are changing as above etc to the prosilver_ip.cfg
It's also obvious that IP templates don't use image size - so if you want to force image sizes - add them to the above strings.
Great stuff - nested templates -
PIGS A***!
