Hi, one of my portals currently runs on Integramod 2, I'm looking to move it to Icy P.
One Idea I have is to first convert it to a standard phpbb2 forum then convert to phpbb3, then to Icy P, does anybody have any advice/suggestions on this?
Converting From Other Portal System To Icy?
Subject: Re: Converting From Other Portal System To Icy?
convert to PhpBB2 and from there to Icy
PhpBB3 is“nt Icy convertible
best way IMHO is : Integra -> PhpBB2 -> Icy 1.2.0.27c -> Icy 1.3.0.53a
The last time I did a conversion was from PHPBB-DE to integra, all I did was dropped all the table s I didn't want but kept the tables I did such as user posts, users, PMs, PM text, forums, forum text etc. etc. then exported the DB then installed integra and then dropped the tables i had saved in the db and then uploaded the saved db which put the bits back in place.
I did screw some text up in some posts but seemed to work fine since, in fact its been running for the past 6 years now LOL so I may try the same.
The only difference this time is I'm going from a phpbb2 setup to a phpbb3 setup, ill do some test runs first with a copy of original DB
phpBB3 doesn't come into the equation if you're upgrading an existing phpbb2 database to Icy Phoenix.
And I think spydie said that? :shock:
Icy Phoenix (or so I found out by "Reading") has a conversion application in its install folder to clean phpbb2 SQL and prepare it for IP.
The usual result for most of these conversions is, if you are not aware - only convert forums, topics, posts and users, and maybe some other basic stuff.
One can only assume that if you were to do this with a copy of Icy Phoenix - You would only have to take the inserts and drop them into your already existing DB while making sure the _PREFIX is the same as what's already there.
Disclaimer:
Read my Signature! :mryellow:
Disclaimer:
I would just try using basic instructions (if it doesn't work I would then wonder...):
How To Upgrade From phpBB 2
Readme
Readme
Hi Luca, its IntegraMOD 1.4.1 that I'm looking to convert over from with my other site.
I know bits about coding but that's it, just enough get by really.
Ive done a copy of the original db so I can practice without messing the site up.
I am a little green when it comes to the coding but always seem to suss things out in the end :mrgreen:
Ill strip the database down so is a basic phpbb hopefully then follow your procedure.
Thanks for the help 8)
I haven't been on here long literary a week so not had a chance to read a lot of whats on the site as Ive also been doing the other site and had to learn that as a lot of features are different to what I'm used to using, and Rome wasn't built in a week :D
mort wrote: [View Post]
That's what I meant when I said "Icy Phoenix (or so I found out by "Reading") has a conversion application in its install folder to clean phpbb2 SQL and prepare it for IP", and assumed that clean_tables_ip.php was there to do just that.
I know, but you weren't in charge of that project! :LOL:
I'm just being facetious! :P
batman wrote: [View Post]
Man thats a fancy word for this late in the morning :bash:
At last got the integra downgraded to phpbb2 and fully working with all old threads users etc, so time to try and upgrade to IP
EDIT:
Think it was a success, GULP :shock: :mrgreen:
EDIT:
Hi there!
I got the same problem about converting...nearby.
Let me tell you, what i got:
- I have install for the first time Icy Phoenix 1.3.0.53b into a new subdomain.
- I have a phpbb 3.0.8 (see my signature please) with many postings, threads and forums/categories.
- I want now converting this important things from phpbb3 to the allnew icy included all important permissions and restrictions to usergroups and forums...
... But how?
Just need to know how i can convert my users and so on to the new icy phoenix.
Please, can you help me further?
Thank you very much!
Best Greetings, testi* ;)
P.s.: Yes of course i've searched this forum, so im landed into this thread! ;)
... But how?
Question.
Is your PhpBB3 instalation an update from PhpBB2 ???
When normaly the original db structure from PhpBB2 should be still present.
you could try to do a copy of your db, install it in an seperate database with an copy of your forum.
when you upload only install folder and execute install/database_update.php
afterwards, delet all files of your root folder ( excluding config.php) + adm, includes, blocks, docs, template and themes folders and upload the icy ones.
then execute install/install.php and run through all options one by one.
Hi there!
Well, unfortunely it was a fresh install from phpbb 3.0.6! Never used phpbb 2!
And i really dont know what i should do first/now. -.-"
We really need conversions script. I know that there's a script from Icy to phpBB3 but apparently, we can't go the other way ... Let's add that to do the to-do list ... So, for now on, until you have so knowledge of "reverse engineering" (meh, not really) or PHP skills + some phpBB3 tables knowledge, there isn't an automated update script.
Generation Time: 0.0927s (PHP: 23% SQL: 77%)
