SOLVED Social Share Buttons?
Goto page 1, 2, 3  Next
Subject: Social Share Buttons?
Hya folks I'm looking for some advice on how to ad a different kind of setup for the share buttons.
I think the one that comes with IP is too much so would like to streamline it a little.
Below is the kind of Idea I'm looking for, any ideas on how to go about this or is it possible to ad the below idea direct to IP?
Maybe added to the current area were the print page icon is as in this pick?
01_04_2011_17_06_32
01_04_2011_16_53_16
http://www.addthis.com/
Subject: Re: Social Share Buttons?
you might do something like a sliding div there
easy job with some javascript
Hi batman...
try to put your code from addthis.com in the file templates/default/breadcrumbs_vt.tpl before <!-- IF S_SHOW_ICONS -->
you may need to edit the code to work with the vietopic urls... i think {U_VIEW_TOPIC_BASE} is the var for this...
Hya spydie, to be honest Im not that bothered about having a dropdown and only really want the facebook and twitter buttons, possibly a couple of others?
Here is a small bit of javascript, how would I insert this into the forum topic?
I obviously don't need the email part so would get rid of that bit.
Or is there a piece of code I could use via my own files?
I'm not a coder so all looks rocket science to me LOL
<!-- AddToAny BEGIN -->
<div class="a2a_kit a2a_default_style">
<a class="a2a_dd" href="http://www.addtoany.com/share_save">Share</a>
<span class="a2a_divider"></span>
<a class="a2a_button_facebook"></a>
<a class="a2a_button_twitter"></a>
<a class="a2a_button_email"></a>
<script type="text/javascript" src="http://static.addtoany.com/menu/page.js"></script>
<!-- AddToAny END -->
EDIT:
Thanks KugeLSichA ill try that 8)
Im a bit stuck on this bit, not sure what I need to do now?
This is with the code added.
{IMG_TBL}<div class="forumline nav-div">
<p class="nav-header"><a href="{U_PORTAL}">{L_HOME}</a>{NAV_SEP}<a href="{U_INDEX}">{L_INDEX}</a>{NAV_CAT_DESC}</p>
<div class="nav-links">
<div class="nav-links-left">{CURRENT_TIME}&nbsp;&bull;&nbsp;{S_TIMEZONE}</div>
<!-- AddThis Button BEGIN -->
<div class="addthis_toolbox addthis_default_style ">
<a href="http://www.addthis.com/bookmark.php?v=250&amp;pubid=ra-4d96115948e7a7c8" class="addthis_button_compact">Share</a>
<span class="addthis_separator">|</span>
<a class="addthis_button_preferred_1"></a>
<a class="addthis_button_preferred_2"></a>
<a class="addthis_button_preferred_3"></a>
<a class="addthis_button_preferred_4"></a>
<script type="text/javascript">var addthis_config = {"data_track_clickback":true};</script>
<script type="text/javascript" src="http://s7.addthis.com/js/250/addthis_widget.js#pubid=ra-4d96115948e7a7c8"></script>
<!-- AddThis Button END --> <!-- IF S_SHOW_ICONS -->
<a href="{U_VIEW_OLDER_TOPIC}"><img src="{IMG_LEFT}" alt="{L_VIEW_PREVIOUS_TOPIC}" title="{L_VIEW_PREVIOUS_TOPIC}" /></a>
<a href="{U_RECENT}"><img src="{IMG_RECENT_TOPICS}" alt="{L_RECENT}" title="{L_RECENT}" /></a>
{S_WATCH_TOPIC_IMG}
{S_MARK_AR_IMG}
<!-- IF not S_BOT -->{S_KB_MODE_IMG}<!-- ENDIF -->
<a href="{DOWNLOAD_TOPIC}" title="{L_DOWNLOAD_TOPIC}"><img src="{IMG_FLOPPY}" alt="{L_DOWNLOAD_TOPIC}" title="{L_DOWNLOAD_TOPIC}" /></a>
<!-- IF S_LOGGED_IN --><a href="{U_BOOKMARK_ACTION}"><img src="{IMG_BOOKMARK}" alt="{L_BOOKMARK_ACTION}" title="{L_BOOKMARK_ACTION}" /></a><!-- ENDIF -->
<!-- IF U_TOPIC_VIEWED --><a href="{U_TOPIC_VIEWED}"><img src="{IMG_VIEWED}" alt="{L_TOPIC_VIEWED}" title="{L_TOPIC_VIEWED}" /></a><!-- ENDIF -->
<a href="{U_PRINT}" title="{L_PRINT}"><img src="{IMG_PRINT}" alt="{L_PRINT}" title="{L_PRINT}" /></a>
<a href="{U_TELL}" title="{L_TELL}"><img src="{IMG_EMAIL}" alt="{L_TELL}" title="{L_TELL}" /></a>
<a href="{U_VIEW_NEWER_TOPIC}"><img src="{IMG_RIGHT}" alt="{L_VIEW_NEXT_TOPIC}" title="{L_VIEW_NEXT_TOPIC}" /></a>
<!-- ENDIF -->
<!-- IF S_SHOW_LINKS -->
<a href="{U_RECENT}" title="{L_RECENT}" />{L_RECENT}</a>&nbsp;&bull;&nbsp;
<a href="{U_PRINT}" title="{L_PRINT}">{L_PRINT}</a>&nbsp;&bull;&nbsp;
<a href="{U_TELL}" title="{L_TELL}">{L_TELL}</a>&nbsp;&bull;&nbsp;
<!-- IF S_LOGGED_IN --><a href="{U_BOOKMARK_ACTION}" class="genmed">{L_BOOKMARK_ACTION}</a>&nbsp;&bull;&nbsp;<!-- ENDIF -->
<!-- IF U_TOPIC_VIEWED --><a href="{U_TOPIC_VIEWED}" class="genmed">{L_TOPIC_VIEWED}</a>&nbsp;&bull;&nbsp;<!-- ENDIF -->
{S_WATCH_TOPIC}&nbsp;&bull;&nbsp;
{U_MARK_ALWAYS_READ}&nbsp;&bull;&nbsp;
<a href="{U_VIEW_OLDER_TOPIC}">{L_VIEW_PREVIOUS_TOPIC}</a>&nbsp;&bull;&nbsp;
<a href="{U_VIEW_NEWER_TOPIC}">{L_VIEW_NEXT_TOPIC}</a>
<!-- ENDIF -->
</div>{IMG_TBR}
ok it seems you dont need to add the var for the topic url...
i tested it quick, and it seems you only need to add the code from addthis.com....
maybe you can try it a bit... if the url is send correctly... but it should...
Hya KugeLSichA nothing is showing up for me, I inserted the code saved and then cleared cache but still doesn't show up?
depending on the code you posted earlier... it works for me...
do you have other styles installed?
check if there is also a breadcrumbs_vt.TPL you need to edit
You may have used the first code I posted? I used this from post #1
Im using prosilver_ip and latest IP
EDIT:
Sorted it now, has the breadcrumbs_vt.tpl within prosilver_ip
Just need to try and get it on the right line as the other icons now, 8)
01_04_2011_21_15_34
EDIT:
Sorted just removed the </div> and included an extra <br /> before to give a bit more space.
<br /><!-- AddThis Button BEGIN -->
01_04_2011_21_29_50
Thanks for your help on this, much appreciated, I'm sure you agree that its a nicer option 8)
i´m glad you solved this... marked as solved
Been having a play and looks good in the menu also, I used the nav menu ad feature to place it there, although Id have to get rid of the sponsor bit some how :?
Probably better to just create a new block.
01_04_2011_22_28_24
01_04_2011_22_29_07
I decided to remove this from the actual topic view as only registered users are able to read the threads.
I now have it on both index and forum above all left blocks.
The only problem with it is its set to align left, probably on the server side, is there anyway of adding some script to it to override and set to align center?
04_04_2011_02_48_01
batman wrote: [View Post]
01_04_2011_21_29_50
What code did you use to get you out there and where you have inserted?
You can put the entire code file breadcrumbs_vt.tpl? :)
I have prosilver_ip ;)
nos wrote: [View Post]
01_04_2011_21_29_50
Hya nos.
templates/prosilver_ip/breadcrumbs_vt.tpl insert code before <!-- IF S_SHOW_ICONS --> on line #31
Working in my web. Thanks
Done some more playing and got it perfect now :)
05_04_2011_18_25_00
Page 1 of 3
Generation Time: 0.0777s (PHP: 28% SQL: 72%)
