Post What Is, Permanentemente Letto?
EDIT: Sorry. I just looked on this site and it means Permanently Read. So, does anyone know which file I have to edit to change this? Thank you in advance.
OP.
Hello all
I'm using the latest IP with the Lightning theme (which I love) and noticed a ribbon of sorts with the words 'Permanentemente Letto' beside it. Does anyone know what this is or means? I'm guessing permanent (something) ban, maybe?
 ip_theme
nothereSend private message
Post Re: What Is, Permanentemente Letto?
This looks very strange to me...
You are using english lang and have italian words as well?
Anyway, can you check lang_main.php
There should be something like this
    'No_new_posts_global_announcement' => 'No new [ Global Ann. ]',
    'New_posts_global_announcement' => 'New [ Global Ann. ]',
    'No_new_posts_announcement' => 'No new [ Announcement ]',
    'New_posts_announcement' => 'New [ Announcement ]',
    'No_new_posts_sticky' => 'No new [ Sticky ]',
    'New_posts_sticky' => 'New [ Sticky ]',
    'No_new_posts_locked' => 'No new [ Locked ]',
    'New_posts_locked' => 'New [ Locked ]',
    'No_new_posts' => 'No new posts',
    'New_posts' => 'New posts',
    'New_post' => 'New post',
    'No_new_posts_hot' => 'No new [ Popular ]',
    'New_posts_hot' => 'New [ Popular ]',
Do you have in this file something like "permanent" ?
Hi, thank you for the reply. There are no words concerning, permanent, in that file, except for the terms of use section; i.e. 'permanently banned'. I have been messing around with some mods, maybe there's a chance that some Italian words have slipped in? Other than that, the site uses English and nothing else. Additionally, I think it's just with the Lightning theme, but will double check to be sure.
Here is what I have in the lang_main.php: which looks the same as you posted.
It is kind of odd, however.
Where did you download Lightning theme?
Do you have a link for me.
i would look at viewforum.tpl
at the icon part there
Hello,
Thank you for the replies.
I obtained the Lightning theme from the discussion forum in English Chit Chat, specifically, This Post, which on page 2, Here (post #27).
I finally found the culprit and have no idea whatsoever how the file got there. In any case it was the 'lang_main_upi2db.php' in the 'language/lang_english' directory.
I kept a backup of this file (the non-English one) and attached it to this message.
Thanks, once again for the help. Greatly appreciated! SOLVED
lang_main_upi2db.zip
Filename: lang_main_upi2db.zip
Filesize: 1.55 KB
Downloaded: 173 Time(s)
