This is the display code from album_pic script
- switch ( $pic_filetype )
- case '.png':
- header('Content-type: image/png');
- break;
- case '.gif':
- header('Content-type: image/gif');
- break;
- case '.jpg':
- header('Content-type: image/jpeg');
- break;
- default:
- die('The filename data in the DB was corrupted');
- readfile(ALBUM_UPLOAD_PATH . $thispic['pic_filename']);
- exit;
This is the display code from album_thumbnail
- if( ($pic_filetype != '.jpg') and ($pic_filetype != '.png') and ($pic_filetype != '.gif') )
- // GD does not support GIF so we must SEND a premade No-thumbnail pic then EXIT
- readfile($images['no_thumbnail']);
- exit;
- else
- // Check thumbnail cache. If cache is available we will SEND & EXIT
- if( ($album_config['thumbnail_cache'] == 1) and ($pic_thumbnail != '') and file_exists(ALBUM_CACHE_PATH . $pic_thumbnail) )
- switch ($pic_filetype)
- case '.gif':
- case '.jpg':
- break;
- case '.png':
- break;
- readfile(ALBUM_CACHE_PATH . $pic_thumbnail);
- exit;
- // Hmm, cache is empty. Try to re-generate!
- $pic_size = @getimagesize(ALBUM_UPLOAD_PATH . $pic_filename);
- $pic_width = $pic_size[0];
- $pic_height = $pic_size[1];
- $gd_errored = FALSE;
- case '.gif':
- $read_function = 'imagecreatefromgif';
- $pic_filetype = '.jpg';
- break;
- case '.jpg':
- $read_function = 'imagecreatefromjpeg';
- break;
- case '.png':
- $read_function = 'imagecreatefrompng';
- break;
- $src = @$read_function(ALBUM_UPLOAD_PATH . $pic_filename);
- if (!$src)
- $gd_errored = TRUE;
- $pic_thumbnail = '';
- else if( ($pic_width > $album_config['thumbnail_size']) or ($pic_height > $album_config['thumbnail_size']) )
- // Resize it
- if ($pic_width > $pic_height)
- $thumbnail_width = $album_config['thumbnail_size'];
- $thumbnail_height = $album_config['thumbnail_size'] * ($pic_height/$pic_width);
- else
- $thumbnail_height = $album_config['thumbnail_size'];
- $thumbnail_width = $album_config['thumbnail_size'] * ($pic_width/$pic_height);
- $thumbnail = ($album_config['gd_version'] == 1) ? @imagecreate($thumbnail_width, $thumbnail_height) : @imagecreatetruecolor($thumbnail_width, $thumbnail_height);
- $resize_function = ($album_config['gd_version'] == 1) ? 'imagecopyresized' : 'imagecopyresampled';
- @$resize_function($thumbnail, $src, 0, 0, 0, 0, $thumbnail_width, $thumbnail_height, $pic_width, $pic_height);
- else
- $thumbnail = $src;
- if (!$gd_errored)
- if ($album_config['thumbnail_cache'] == 1)
- // Re-generate successfully. Write it to disk!
- $pic_thumbnail = $pic_filename;
- case '.jpg':
- @imagejpeg($thumbnail, ALBUM_CACHE_PATH . $pic_thumbnail, $album_config['thumbnail_quality']);
- break;
- case '.png':
- @imagepng($thumbnail, ALBUM_CACHE_PATH . $pic_thumbnail);
- break;
- @chmod(ALBUM_CACHE_PATH . $pic_thumbnail, 0777);
- // After write to disk, donot forget to send to browser also
- case '.jpg':
- @imagejpeg($thumbnail, '', $album_config['thumbnail_quality']);
- break;
- case '.png':
- @imagepng($thumbnail);
- break;
- exit;
- else
- // It seems you have not GD installed :(
- readfile('images/nothumbnail.jpg');
- exit;
This is a screen of personal album page in Firefox (using thumbnail script)
This is a screen of personal album page in IE (using thumbnail script)
This is a screen of pic page in IE (using pic script)
This is a screen of pic page in Firefox (using pic script)
| Photo Album Add-on.zip | ||
| Description: | here is the ported mod thus far |  Download |
| Filename: | Photo Album Add-on.zip | |
| Filesize: | 139.21 KB | |
| Downloaded: | 313 Time(s) | |
 Earth, Europe, the Netherlands, Rotterdam
 Borgo San Michele
 Borgo San Michele
