After Add:
- 'search' => array(
- 'nested' => true,
- 'inurl' => false,
- 'allow_empty' => false,
Find:
// IMG
if($tag === 'img')
global $config_mg;
if($this->is_sig)
return $error;
// main parameters
$params = array(
'src' => false,
'alt' => false,
'slide' => false,
// additional allowed parameters
$extras = $this->allow_styling ? array('width', 'height', 'border', 'style', 'class', 'title', 'align') : array('width', 'height', 'border', 'title', 'align');
// [img=blah]blah2[/img]
if(isset($item['params']['param']))
$params['src'] = ($config_mg['thumbnail_posts'] == 1 ) ? "image_thumbnail.php?pic_id=" . $item['params']['param'] : $item['params']['param'];
$params['alt'] = $content;
$params['slide'] = isset($item['params']['slide']) ? $item['params']['slide'] : '';
$slideshow = ($params['slide']) ? 'lightbox[' . $item['params']['slide'] . ']': 'lightbox';
// [img src=blah alt=blah width=123][/img]
elseif(isset($item['params']['src']))
$params['src'] = ($config_mg['thumbnail_posts'] == 1 ) ? "image_thumbnail.php?pic_id=" . $item['params']['src'] : $item['params']['src'];
$params['alt'] = isset($item['params']['alt']) ? $item['params']['alt'] : $content;
for($i=0; $i<count($extras); $i++)
if(!empty($item['params'][$extras[$i]]))
if($extras[$i] === 'style')
$style = $this->valid_style($item['params']['style']);
if($style !== false)
$params['style'] = $style;
else
$params[$extras[$i]] = $item['params'][$extras[$i]];
// [img]blah[/img], [img width=blah]blah[/img]
elseif(!empty($content))
//Added in 033 -LIW -BEGIN
if ( $config_mg['thumbnail_posts'] != 1 && $max_image_width != 0 && $board_config['liw_enabled'] == 1 && !$this->is_sig && (!$item['params']['width'] || $item['params']['width'] >= $max_image_width))
$image_size = @getimagesize($content);
$item['params']['width'] = ($image_size[0] > $max_image_width) ? $max_image_width : $item['params']['width'];
//Added in 033 -LIW -END
$link_url = $content;
$params['src'] = ($config_mg['thumbnail_posts'] == 1 ) ? "image_thumbnail.php?pic_id=" . $content: $content;
$params['alt'] = isset($item['params']['alt']) ? $item['params']['alt'] : (isset($params['title']) ? $params['title'] : '');
else
// generate html
$html = '<img';
foreach($params as $var => $value)
$html .= ' ' . $var . '="' . $this->process_text($value) . '"';
if(!isset($params['title']))
$html .= ' title="' . $this->process_text($params['alt']) . '"';
$html .= ' />';
// add url
if(empty($item['inurl']))
$html = ($config_mg['thumbnail_posts'] == 1 ) ? '<a href="' . $link_url . '" rel="'.$slideshow.'" title="' . $params['alt'] . '">' . $html . '</a>' : '<a href="' . $params['src'] . '" target="_blank" title="' . $lang['OpenNewWindow'] . '">' . $html . '</a>';;
return array(
'valid' => true,
'html' => $html,
'allow_nested' => false,
if($tag === 'img')
global $config_mg;
if($this->is_sig)
return $error;
// main parameters
$params = array(
'src' => false,
'alt' => false,
'slide' => false,
else
else
// generate html
$html = '<img';
$html .= ' />';
// add url
return array(
'valid' => true,
'html' => $html,
After Add
//Search
if($tag === 'search')
// if($this->is_sig)
// return $error;
if($item['iteration'] > 1)
return $error;
$str = '<a href="search.php?search_keywords=' . $content . '" target="_blank">';
return array(
'valid' => true,
'start' => $str,
'end' => '</a>'
// return $error;
return $error;
return array(
'valid' => true,
'start' => $str,
'end' => '</a>'
No icon now!! Sorry
