PigeonMadness
 Need Help With Adding Mods
Hello,
I absolutely love the the Frozen Phoenix style but I've ran into a little bit of problem when it comes to adding MODs. As I did for the Advertisement Management Mod, I just implemented the instructions for prosilver into the Frozen Phoenix style with success. But I've tried to add mods such as the phpbb statistics mod and when I look for the specific codes such as <li class="icon-faq"><a href="{U_FAQ}" title="{L_FAQ_EXPLAIN}">{L_FAQ}</a></li> within the overall_header.html for frozen phoenix it's not there. There's been a couple other mods with the same results. I don't know if they're placed in a different area or do not exist but any help with this would be great. Please let me know as soon as possible. Thanks in advance!
#1 Wed 04 Jan, 2012 22:03 |
Joshua203
Joshua 203
Dutch A Go Go
 Re: Need Help With Adding Mods
Hi PigeonMadness,
Welcome to IcyPhoenix.
Just so we can put your question in the right forum, you are talking about using Frozen Phoenix on phpbb ..right?
#2 Wed 04 Jan, 2012 22:34 |
PigeonMadness
Yes. Sorry if it's in the wrong place.
#3 Wed 04 Jan, 2012 22:58 |
Joshua203
Joshua 203
Dutch A Go Go
Never mind ... common mistake
Please take a look at menu_block.html for the code you search
#4 Wed 04 Jan, 2012 23:12 |
PigeonMadness
Joshua203 wrote: [View Post] Never mind ... common mistake
I just did and could not find it. Am I looking in the wrong place or can it be located somewhere else?
#5 Thu 05 Jan, 2012 03:51 |
spydie
it´s defenitly in menu_block.html, but it might look a bit different to the code you are used to
instead of <li> you´ll have <ahref> and so on,
this means, you´ll have to adapt the code you want to insert there
____________ Out of Order
#6 Thu 05 Jan, 2012 11:10 |
Joshua203
Joshua 203
Dutch A Go Go
If you post an example of one of the replaces you can't find ("find code" in one codeblock and "replace code" in another) I'll take a look for you.
Spydie is right the content of that file does look different, so you should look for similarities and not the exact code.
EDIT:
incase you mean you can't find the whole file .... styles/frozen_phoenix/template/menu_block.html
#7 Thu 05 Jan, 2012 14:30 |
spydie
... when I look for the specific codes such as <li class="icon-faq"><a href="{U_FAQ}" title="{L_FAQ_EXPLAIN}">{L_FAQ}</a></li> within the overall_header.html for frozen phoenix it's not there.
maybe, looking for this ??
<a href="{U_FAQ}">{L_FAQ}</a>
#8 Thu 05 Jan, 2012 15:24 |
PigeonMadness
I got it! Thanks guys. You were right, it looked similar but it was not the exact same. I didn't know if it was the right code but added it and the mod works so thanks again! I thought that this was gonna stop me from using such a nice looking style but nope! Thanks again.
#9 Thu 05 Jan, 2012 23:24 |
Joshua203
Joshua 203
Dutch A Go Go
You're welcome PigeonMadness, I'll mark the thread solved.
#10 Fri 06 Jan, 2012 07:37 |
| Link this topic |
| URL |
| BBCode |
| HTML |
Similar Topics
Similar Topics
