is there any want to have a right sidebar on milky way theme?
I really like the milky way theme and I want to customize it with a sidebar.
Any help please?
Thanks!
Right Sidebar On Milky Way
Subject: Re: Right Sidebar On Milky Way
Hi Saber,
Yeah that should be possible, the next links should give you some clues (even if those are for other styles!)
http://www.icyphoenix.com/viewtopic...ght=side#p51372
http://www.icyphoenix.com/viewtopic...=sidebar#p48402
I'm almost sure if you use the search function of the board there will be some more :wink:
Offtopic tip: be carefull what IP-numbers you use, you tend to use blacklisted ones here and there :mricy:
Thanks I will read it..
My IP? Im from Philippines. So some IP here are banned?
No not yours, not here, what I meant is that some of your IP's happen to be blacklisted in a database (stop forum spam), if you like you can use the IP Spy in the portal at my site to see the reports (linked in the sig below).
I just thought you should know :wink:
Is there anyway to put login bar on my sidebar? tried copying the login form on indexbody but have no luck..
I would like o add the statistics, the userlogin, and the legend on the sidebar to minimize the height of my forum..
Thanks!
Thanks!
I'm not quite sure what you mean, but if you mean what i think you mean... have you tried something like this?
If it's not what you mean, please try to explain more by giving a link, your failing code, screenshots or whatever it takes to make it clear :wink:
I want to have this on my sidebar..
http://i48.tinypic.com/2w4g000.jpg
but ofcourse using the milky way theme.
I also want to have the list of the category on my sidebar.
BTW, thanks for the fast reply. :mricy:
Well this is starting to sound more like a mod request :mryellow:
If you would like the loginbox to disapear after the user has logged in it should not be so hard, you could take a close look at this example and rewrite it to fit your box:
(Strip what you don't need and make sure it's not all in one line anymore)
Otherwise I would start researching how one of the many available portals do this, they usually show user stuff (like name, avatar etc) after the login.
I hope you do realize the box is already in the index page when a user is not logged in, so that one + the one in the top menubar + your idea would give you 3 ways to login on one page, isn't that a bit too much of a good thing?
<!-- IF not S_USER_LOGGED_IN and not S_IS_BOT -->
<br clear="all" />
<form method="post" action="{S_LOGIN_ACTION}">
<div><div class="tbl-h-l"><div class="tbl-h-r"><div class="tbl-h-c"><div class="tbl-title"><h4><a href="{U_LOGIN_LOGOUT}">{L_LOGIN_LOGOUT}</a></h4></div></div></div></div>
<table class="tablebg" width="100%" cellpadding="0" cellspacing="0">
<td class="row1" align="center" valign="middle"><img src="{T_THEME_PATH}/images/login.png" alt="" /></td>
<td class="row1" align="center"><span class="genmed">{L_USERNAME}:</span> <input class="post" type="text" name="username" size="10" /> <span class="genmed">{L_PASSWORD}:</span> <input class="post" type="password" name="password" size="10" /> <!-- IF S_AUTOLOGIN_ENABLED --> <span class="gensmall">{L_LOG_ME_IN}</span> <input type="checkbox" class="radio" name="autologin" /><!-- ENDIF --> <input type="submit" class="btnmain" name="login" value="{L_LOGIN}" /></td>
<tr><td class="cat-bottom" colspan="2"> </td></tr>
</table>
<div class="tbl-f-l"><div class="tbl-f-r"><div class="tbl-f-c"> </div></div></div></div>
{S_LOGIN_REDIRECT}
{S_FORM_TOKEN}
</form>
<!-- ENDIF -->
<br clear="all" />
</table>
{S_LOGIN_REDIRECT}
{S_FORM_TOKEN}
</form>
<!-- ENDIF -->
Generation Time: 0.2831s (PHP: 10% SQL: 90%)
