Post Missing Reply Button In Private Messages
Hi all
I just have seen that in my Board the reply button in the private messages is missing. Instead of thes button only a text is shown.
Can some body please tell me where I can fix this problem?
Thanks a lot
Faethor
Filesize: 9.09 KB
Viewed: 283 Time(s)
faethorSend private message
Post Re: Missing Reply Button In Private Messages
Hi again Faethor,
Please check if these buttons really exist, probably the german one is missing:
/styles/black_pearl/imageset/en/button_pm_s_reply.png
/styles/black_pearl/imageset/de/button_pm_s_reply.png
Hi Joshua
Are you the only one who gives support here?
Yes, those buttons are existing, in bothe language folders. I checked this before I posted my problem. Probably I damaged the code somewhere... but I cant find it
Cheers
F.
faethor wrote: [View Post]
No but I am one of the few that is actually using phpbb, so as long as you don't ask what I can't answer not many feel the need to bother?
Ok well I've checked the same thing (sorry I didn't do that in the first place, had to find the post where you gave us the link first).
We can go 2 ways to see what's going on:
- You can create a test-user account and PM me the login details (so i can take a look without registering)
- You can start by right clicking the link (where the button should be and tell me the url to the image you see in properties of the link/missing image
Off Topic
BTW I think you forgot to revert the css edit that I told you change back, and you did not do the edit in overall_header yet (both to try and remove the space above your forum)
Edited by Joshua203, Thu 30 Aug, 2012 13:30: off topic added!
Josh, No, no, Im pretty glad that you always giving me that good help
Hmmm, Yes, I didnt changed back the css edit I've made I will do that soon
Well this login does n't help me much since I can not see any link or any button, must be a mistake in your ACP that does not permit me to send PM's   (edit: I am permitted to PM but still no buttons or links of buttons visible ....   strange)
BUT!!!
I did have a look at you imageset.cfg and it's very confusing to say the least.
My advice is to at least upload the default .cfg and then only add the buttons you added (not rewrite what is already there)
I would also remove all the unused images (mostly .gif) to a. not waste any space and b. avoid more confusion.
Right now this button is pointing to a .gif in your cfg, while in fact it is a .png
Actually they are all pointing to .gifs while in reality only your newly added buttons are or should be .gif
Are you logged in with english? In the german image.cfg its right:
Now you should see the buttons, the en imageset.cfg was renamed in _imageset.cfg
Sorryyyyyy
well TBH I must have been talking about one of the old renamed .cfg's, but in the real file the button_pm_s_reply.png was called button_pm_s_reply I think... so it was missing the extension
EDIT: anduhh yes I now see the buttons too    congrats!!!!
Off Topic
I guess you are still working on this but I have to avoid hitting the portal as a regged user ATM
Language file ./language/en/mods/portal/portal_shoutbox_module.php couldn't be opened.
This means your english file is missing ... german seems to be ok
Hehe Good are you testing.
The shoutbox I integrated by myself, just forgot to do the changes in the english language.
Good that you are seeing the buttons. The PM reply button is still not available in de
Already refreshed the style?
Yes, I always do that.
Sorry I mean the image set (ACP >> style Tab)
Ouuuuuuuuuuuuchhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh
No, this one i have forgotten. Now its working
Thanks again a lot for your helping!!
Cherrs
Anytime
HideSimilar Topics
