ClanMayo
 Home In Mobile Version
I would know how to do it, to change the home page for the mobile version. I want add the donations block for the mobile version.
Anybody can help me in this question?
____________ Thank's & Regards,
ClanMayo
Support for:
TMAXERSCLUB
IP version: 2.0.0.86
Template: ProSilver IP Blue
#1 Fri 19 Oct, 2012 09:42 |
Joshua203
Joshua 203
Dutch A Go Go
 Re: Home In Mobile Version
I think if you add a new parent block in cms containing the paypal code you want to use and then add it to your portal it would show up in both the normal style and mobile style
#2 Sat 20 Oct, 2012 15:02 |
ClanMayo
Hi Joshua,
In CMS already exist the parent block paypal and his paypal code was created directkly in Paypal. I can usually see the block in PC version, but not in mobile version.
Paypal_block.tpl file, located in /templates/default/blocks/ should have something referred to mobile version? Thanks, best regards...
ClanMayo
Support for:
TMAXERSCLUB
#3 Sat 20 Oct, 2012 23:08 |
Joshua203
Joshua 203
Dutch A Go Go
Sorry, it seems that you are right, I assumed the above because when I navigate to IcyPhoenix with my mobile I do see a paypal block.
Looking a bit deeper, I even doubt if the mobile style is installed here because it's not in any of my dropdown menu's to choose it.
Maybe someone else can jump in here because I'm lost TBH
#4 Mon 22 Oct, 2012 15:10 |
Costa
To see it in (mobile style) you have to put the block, in the center of the page and not to the left or right.
The left and right I noticed that it shows when is HTML content in the block.
There may be another way that I does not know.
#5 Mon 22 Oct, 2012 20:32 |
ClanMayo
Hi Costa,
I've proved to move the donations block to the center of the page and also I've cleaned the cache after. The same case, I can see normally on PC style, but not in the mobile style.
Any other idea?
F.ex. rewrite any HTML content in this block file or others?
ClanMayo
Support for:
TMAXERSCLUB
#6 Mon 22 Oct, 2012 23:15 |
Costa
what is u site so I can see it with iPhon
#7 Tue 23 Oct, 2012 00:19 |
ClanMayo
http://www.tmaxersclub.com/foro
The info for support is on my signature, I've configuratet it on my profile but I don't know because this is not shown.
ClanMayo
Support for:
TMAXERSCLUB
#8 Tue 23 Oct, 2012 07:15 |
Joshua203
Joshua 203
Dutch A Go Go
That's all part of spam protection ClanMayo, it will be lifted from your account very soon
#9 Tue 23 Oct, 2012 16:51 |
ClanMayo
Ok Joshua203, understand...
Well, take the opportunity to inform that the problem is solved.
A) In parent block must unmark "file" in block type.
B) Mark "text in BBcode" and introduce the text in this format. The HTML format is not recognized.
C) Upgrade your browser.
I hope this information helps for all. Best regards.
#10 Tue 23 Oct, 2012 19:58 |
 Re: [SOLVED] Home In Mobile Version
Unfortunately I had to force some blocks not being shown in Mobile version... I have to review the whole style, because there are other things I don't like. Unfortunately it won't happen soon.
#11 Sat 17 Nov, 2012 12:01 |
| Link this topic |
| URL |
| BBCode |
| HTML |
