ClanMayo
 New Messages
In the IP 2.0, the new messages are not marked as read when you close your explorer and you open it again in the same or another computer.
What to do to repair it?
____________ Thank's & Regards,
ClanMayo
Support for:
TMAXERSCLUB
IP version: 2.0.0.86
Template: ProSilver IP Blue
#1 Thu 25 Oct, 2012 13:00 |
mort
 Spam Basher
 Re: New Messages
You need to log out.
#2 Thu 25 Oct, 2012 13:10 |
ClanMayo
 Re: New Messages
Yes, but disconnect and connect each day to not see posts of yesterday.
Another solution without log out?
ClanMayo
Support for:
TMAXERSCLUB
#3 Thu 25 Oct, 2012 14:26 |
Joshua203
Joshua 203
Dutch A Go Go
 Re: New Messages
Use Upi2DB system instead of cookie based and then click on U(#) for unread messages
#4 Thu 25 Oct, 2012 15:18 |
ClanMayo
 Re: New Messages
I think do you've not understand me. In the previous versions, when you had read a message, this was marked as read.
Now in this new version this is not so and I would have it as before...
My answer is What to do to return to the previous model for read messages, but mantaining the new version 2.0.0.86?
ClanMayo
Support for:
TMAXERSCLUB
#5 Thu 25 Oct, 2012 18:00 |
Joshua203
Joshua 203
Dutch A Go Go
 Re: New Messages
Then do you mean the post icon should change and the topic title colour too?? ...this should actually be working fine
EDIT:
Could it be that you are deleting cookies automatically when you close IE?
#6 Thu 25 Oct, 2012 18:29 |
ClanMayo
 Re: New Messages
No, what I mean is that the read messages are still seen in the list of unread messages. READ messages meet with the really unread.
What to do to change that without logout?
ClanMayo
Support for:
TMAXERSCLUB
#7 Thu 25 Oct, 2012 19:11 |
Joshua203
Joshua 203
Dutch A Go Go
 Re: New Messages
Then I can only say it again...
Do you know how to activate it?
#8 Thu 25 Oct, 2012 19:28 |
ClanMayo
 Re: New Messages
In the ACP --> unread messages?
ClanMayo
Support for:
TMAXERSCLUB
#9 Thu 25 Oct, 2012 19:39 |
spydie
 Re: New Messages
you can try to cut sessions time down by settings
BTW
here it works very well
____________ Out of Order
#10 Thu 25 Oct, 2012 20:08 |
Joshua203
Joshua 203
Dutch A Go Go
 Re: New Messages
Yes, ACP >> configuration >> new posts
And if you set it to "user settings", users can activate it by themsleves, "yes" should force it.
#11 Thu 25 Oct, 2012 20:40 |
ClanMayo
 Re: New Messages
Coming from version 0.53 b where messages were automatically marked as read and did not continue in the message list again, I think it is now very difficult to understand and use it. I would like to have the new version but with messages read list from the previous version. It's easier for users.
ClanMayo
Support for:
TMAXERSCLUB
#12 Fri 26 Oct, 2012 00:02 |
mort
 Spam Basher
 Re: New Messages
[quote user="ClanMayo" post="57233"] I think it is now very difficult to understand and use it.
It has been suggested many times that it's not that user friendly.
If you can convince MG to change it - You will be doing well.
But now I'm going to mark all forums read and log out, so that I don't see them again.
#13 Fri 26 Oct, 2012 05:16 |
Joshua203
Joshua 203
Dutch A Go Go
 Re: New Messages
Well if someone really would like to mess with this, I think there would be a pretty simple way by editing the html in nav_header.tpl:
Find:
<!-- BEGIN switch_upi2db_on -->
<span style="vertical-align:middle;">{L_POSTS}: <a href="{FULL_SITE_PATH}{U_SEARCH_NEW}">{L_NEW2}</a> • {L_DISPLAY_U} • {L_DISPLAY_M} • {L_DISPLAY_P} <img src="{FULL_SITE_PATH}{IMG_MENU_SEP}" alt="" style="vertical-align:middle;" /> </span>
<!-- END switch_upi2db_on -->
Remove:
Remove:
And change the lang variable a little for DISPLAY_U.
Then force everyone to Upi2DB in ACP.
Spydie's idea may be a nice way to shorten the time these posts will show up.
And Mort is right ..there is very little chance MG will revert this change.
EDIT:
TBH I did not like the Upi2DB system either, but I got used to it very fast, it's very accurate
#14 Fri 26 Oct, 2012 08:00 |
ClanMayo
 Re: New Messages
Thanks Joshua203, I'll test it.
ClanMayo
Support for:
TMAXERSCLUB
#15 Fri 26 Oct, 2012 15:20 |
