klaaz
 FAP SUPPORT - Blank Pages ACP
Hello,
I am new here and donwloaded the FAP fotoalbum for my phpbb forum (http://www.lagerscaleonroadforum.nl)
I have read the manual carefully and edit all the files ho was needed, but when I go to my ACP and when I click on one of the 4 links then I get only an blank page.
I hope someone can help me with this problem.
Gr, Klaas
The Netherlands.
#1 Thu 11 Jan, 2007 23:48 |
Artie
 Re: Blank Pages ACP
The link you provided is not valid.
Are you using a template other than subSilver?
If so, did you edit/copy the files for/to that template ?
#2 Fri 12 Jan, 2007 01:05 |
Artie
 Re: Blank Pages ACP
Can you verify this step of the installation:
copy phpbb_root/admin/*.php to admin/*.php
which are these files:
admin/admin_album_personal.php
admin/admin_album_auth.php
admin/admin_album_cat.php
admin/admin_album_config_clearcache.php
admin/admin_album_config_extended.php
admin/admin_album_config_gd_info.php
admin/admin_album_config_index.php
admin/admin_album_config_personal.php
admin/admin_album_config_settings.php
admin/admin_album_config_thumb.php
admin/admin_album_config_upload.php
#4 Sat 13 Jan, 2007 21:27 |
klaaz
 Re: Blank Pages ACP
Yes I copied the files to the admin folder, serval times but I still have blank pages.
See screenshots:
#5 Sat 13 Jan, 2007 23:45 |
Artie
 Re: Blank Pages ACP
Very strange.
There is no error message ?
Do you get the blank page for all 4 of Photo Album admin links ?
Can you view source of the frame that is blank, or click in it and press Ctrl-A to select all, to verify that it is indeed blank.
Highly unlikely, but possible that the text is same color as background here.
#6 Sun 14 Jan, 2007 00:34 |
klaaz
 Re: Blank Pages ACP
When I am not in the CP but at the homepage and click at album then pictures then I get this:
All the 4 links give me an blank page
CTRL a gives me the next screenshot
Has it anything to do with write permissions?
#7 Sun 14 Jan, 2007 00:49 |
Artie
 Re: Blank Pages ACP
Actually, you need to click your cursor in the page's frame that is blank and then Ctrl-A to select all in that frame...... but I doubt that there is anything there. I just want to be sure........ this is strange behavior.
No, do not think there would be any issue with permisssions here.
#8 Sun 14 Jan, 2007 00:59 |
klaaz
 Re: Blank Pages ACP
When I click Ctrl a in the blank frame the it shows nothing, strange but true...
#9 Sun 14 Jan, 2007 01:02 |
klaaz
 Re: Blank Pages ACP
Ok the problem was the language, i had copied the files into english language but i have dutch language, but when I click in the CP on configuration I get now the message:
Template->make_filename(): Error - file ADM_TPLalbum_config_body_extended.tpl does not exist
But the files are still there???
#10 Sun 14 Jan, 2007 01:15 |
Artie
 Re: Blank Pages ACP
That's what I was expecting....nothing there.
I have tried to recreated the problem, but I can not.
At the moment I have not a clue, but I will continue to investigate.
It is probably something simple, but my knowledge of how the ACP code works is not so good.
#11 Sun 14 Jan, 2007 01:16 |
klaaz
 Re: Blank Pages ACP
Ok thanks anyway for your help, would look around if there is anaother fotoalbum for phpbb.
Gr, klaas
#12 Sun 14 Jan, 2007 01:19 |
klaaz
 Re: Blank Pages ACP
Did you read the messaga above your last one?
#13 Sun 14 Jan, 2007 01:28 |
CemetaryMan
 Re: Blank Pages ACP
Where did you put the admin templates ?
#14 Sun 14 Jan, 2007 03:17 |
Artie
 Re: Blank Pages ACP
Did you read the message above your last one?
No, my internet connection is very unpredictable the last few days. I can only visit here when I'm lucky.
You should review your installation and look very close at the phpbb files that you edit.
You did not do the edit for templates/subSilver/subSilver.cfg .... there may be more you overlooked
Did you modify your album_mod/album_constants.php for any reason ?
CemetaryMan, The admin templates are all there in the proper place..... the path is the problem for them.
#15 Sun 14 Jan, 2007 03:31 |
