Page 1 of 4
Goto page 1, 2, 3, 4  Next
Post Cash Mod...
cash mod work in IP?
Desing
KtmDesingz
[spoiler][img]http://i116.photobucket.com/albums/o37/_ktm_/Firma32.jpg[/img][/spoiler]
-ktm-Send private messageVisit poster's website
Post Re: Cash Mod...
I tried with cash mod, but doesn't work... and not only in IP, but in Area69 too. I have installed the points mod with success, with only a little problem: I can't see points in viewtopic.
Post Re: cash mod...
andrea75 wrote: [View Post]
oo    i try too bad not work thanks andrea75
Desing
KtmDesingz
i think that must work
i'll give a try (because i use cash mod on my xs now) when i finally update to icy
Zuker wrote: [View Post]
Yes, on XS Cash Mod works fine, but not in Icy at this moment. Anyway you can use Points Mod in the meantime.
yes I must too this Mod because in my forum pay with this :S
Desing
KtmDesingz
I'll try to help you when the final release will be out.
thanks
Desing
KtmDesingz
Any news guys? I try to install gain Cash Mod instead Points System Mod, but I have an error on viewtopic.php
Fatal error: Call to a member function on a non-object in includesclasses_cash.php on line 369
this is the line
  1. $template->assign_block_vars('cashrow', array(    'CASH_DISPLAY' => $c_cur->display($postdata[$c_cur->db()])));
  2.
Any ideas?
this is the line
  2.
Any ideas?
You should install an eXtreme Style fix I guess...
Anyway, I'll integrate Cash Mod when Icy Phoenix will go final.
Try to check if Difus has this mod successfully installed on his package.
No cash mod @ difus package
Ok... thanks for the info... so I have to play with it...
Or maybe Zuker do you want to be the lucky boy?
i'll play with cash mod if u don't because i've already installed on my xs
but only when gold release is out
Just do it... I have used the classes_cash of XS, but is not enough: the error that I have posted goes out with original and modded file......
Does anyone know if this is being worked on?
Thanks Everyone
-D1-
Check out my new website:
Adult Forums - A place where everyone can fit in.
Currently running v1.1.10.25 RC3
darkoneSend private message
Post new topic  Reply to topic  Page 1 of 4
