Post FAP SUPPORT - Upgrade From Smartor's Album
Is there an "upgrade" file to go from Smartor's Album to FAP? Is it version specific? Any help is appreciated.
JirshSend private message
Post Re: Upgrade From Smartor's Album
There is a file that will upgrade the database, but basically you must remove all of the Smartor file's and edits (any other album mods as well).
## Upgrading from Smartor Album or older FAP or combination of Smartor Album and some Album Mods
## If you are upgrading from older versions of Smartor Album or FAP, you should first uninstall
## the modifications listed in the installation files of those mods, and then apply the ones listed here.
## There is no need to remove the SQL part, since you can use "fap_install.php" to upgrade from any version.
## Just remember that if you are upgrading from older Album version, you may need to run even the
## Personal Galleries migration step from "fap_install.php", just after having installed FAP.
ArtieSend private message
