Post New "Pearl" Buttons And Css
I've made three new sets of border-less buttons (little_box and menu_sep etc.) for Pearl black, blue and white because the existing ones look awful in LoFi.
They're in the zip, but you will have to remove the prefixes I added that denotes what is what.
I've also added a Blank overlay that can be used to "treat" other buttons as required.
There is also a "New" lofi.css to which I've only added some control over the width of the LoFI templates.
No Pics:
Just a Demo:
http://bitzagames.com/forum/index.php?&lofi=1
new-pearl-buttons.zip
Description: Border-less buttons for Pearl Black, Blue and White
Filename: new-pearl-buttons.zip
Filesize: 4.52 KB
Downloaded: 253 Time(s)
Post Re: New "Pearl" Buttons And Css
thanks mort..
why did you wrapped lofi if default is normal non wrepped (but i like it wrapped)
menu_sep is now realy great ,no more that black ugly border
little box i cant find..i dont know where is it in lofi
i think MG shoud consider to made only one lofi template for all styles without any image
because of this
 limun_2013_02_23_06_46_30
Limun wrote: [View Post]
why did you wrapped lofi if default is normal non wrapped (but i like it wrapped)
Because this is ridiculous!
And every theme should have the option to adjust the width - LoFi has NONE?
Window: 1936 X 1056 - - - Viewport: 1920 X 861
 lofi2
I'll have a look at those other templates, but if they're blocks - I wont!
you shoud create sometnig like this
<!-- IF screenresolution_over_1440px-->
<link rel="stylesheet" href="{FULL_SITE_PATH}{T_TPL_PATH}style_{1440}.css" type="text/css" />
<!-- ENDIF -->
just kidding..you are right on large displays its ridiculous
WAHAHAHAHAHAHAHA!
You're right - That's how phpBB would do it and create other arguments for about every other screen resolution at the same time!  JUST TO KEEP IT COMPLICATED
I was going to put it at 85% !important - But my favourite these days is width: 1024px;
And while we're on the subject of "Useless Stuff" - phpBB's change font size is a useless relic that is about as useful as an ashtray on a motorcycle - - - But they like it I suppose - SO YOU HAVE TO HAVE IT!
Oh! and this.
little box i cant find..i don't know where is it in lofi
Just tidying up to keep things looking consistent and nice for when one is not using LoFi.
Modern themes are called "responsive" because they automatically adjust content display according to the visitor device/resolution.
Unfortunately it wouldn't be easy to apply a responsive style to Icy Phoenix, it does require a lot of job.
In a new life I'll recode Icy Phoenix from scratch...
In a new life - I'll help.
But in reality, it's all moving to ahead too fast for this little black duck to keep up with or have a use for.
So I'll just stick to the nuts and bolts and let the younger generation worry about responsive graphics and templates.
