Re: Black Pearl, Title And Description
Problem: I have no title or description in the header. I do have the codes in place but nothing showing? Is there a setting that I might have missed?
Trusting that we are talking about Icy Phoenix?
From what I can see is that the "
Old phpBB title and description" that used to be part of the header has been superseded by adding the "right-side info" as a block advert in the CMS.
CMS -
Global Header
Else copy overall_header.tpl from the "default" to the pearl folder and edit it manually.
For an example:
<div class="sitedes"><img src="{T_IMAGESET_PATH}/logo-right.png" height="147" alt="" title="" /></div>
That's what I do.
Edit:
There should also be a VAR or two that you could add to bring up what you are trying to do, but with my lack of experience these days with IP - you'll have to dig it out.
<div class="sitedes">$VAR</div>
