I'm looking for an option that can prevent image leeching. I want to prevent people using the bandwidth of my site somehow and I wonder if there is an option within Icy Phoenix to do just that. I have been searching for it without any luck.
Thanks in advance for the help.
Is Possible To Prevent Image Leeching?
Subject: Re: Is Possible To Prevent Image Leeching?
To prevent hotlinking you would usually use a tool in your cpanel :wink:
To prevent all images like smilies and so on you can do that with .htaccess
Take a look here:
http://www.icyphoenix.com/viewtopic.php?p=48556#p48556
Take a look here:
which is exactly what the tool in ACP edits :wink:
Is this topic SOLVED? if so please mark the thread as such, thanks in advance :wink:
Generation Time: 0.0929s (PHP: 18% SQL: 82%)
