Post French Translation
Translation hosted at https://github.com/Nami-Doc/icy_phoenix_langs (not updated yet)
Current state (remaining : 19 in total, but 10 are pafiledb, cback and other mods I may find a pre-translated pack)
How it looks like : http://imgur.com/wmW1l0H
I should be able to finish it by the end of august (at least for the ip-specifics)
Just in case :
"à trouver" => I can find those files somewhere else, probably.
"à trouver si possible" => There's somehow a slight hope I can find translation pack for  these files.
SO if you know of somewhere I could find translation packs for these, please tell me =). The only missings that I won't be able to find are lang_xs_news (but who uses that anyway :p ?) and lang_features (I don't even think that should be part of the IP package).
Post Re: French Translation
I can help you in finding the album files, I should have them in an archive on my main PC.
Regarding "features" you are right... I should remove it from the package.
I'll send you the files next week.
Thanks ! Speeds things up quite a bit
Here are some french files for FAP
http://www.icyphoenix.com/dload.php?action=file&file_id=8
Look into "full_album_pack_contrib\languages_old\french"
Here is the last pack I have... maybe it's the same Steffen linked.
fap_lang_french_20051203.zip
Description: FAP Lang French 20051203
Filename: fap_lang_french_20051203.zip
Filesize: 11.55 KB
Downloaded: 753 Time(s)
Thanks, I'll take a look at it.
BTW, lang_main's "Post" overrides auth_post :(.
Propose a fix.
Just use another lang key?
I can help you in finding the album files, I should have them in an archive on my main PC TNS .
Thanks for this post, il's clear and precise.
sarahlabicheSend private message
I can help you in finding the album files, I should have them in an archive on my main PC meubles design
Hi, can you give me a website of translation please. Thanks !
arnaudxmen21Send private message
The french translation is available on this website: https://github.com/vendethiel/icy_phoenix_langs
