Post Make A Style
Hi
Since it has been some time since I was here last, I have unfortunately forgotten most when it comes to creating themes for IcyPhoenix.
So now I wonder what is the best to start with.
Is there a good template that can be used for this?
Is there a good guide to use?
Are grateful for any suggestions.
Will be fun to see what I can do ..
Jogge
JoggeSend private message
Post Re: Make A Style
Hey,
I'm not sure if we have a tutorial for that. I guess you should start off the theme you want to "derive" and change the css and image files. You shouldn't need to change the .tpl files :).
OK, Informpro
Thanks for the tip, i give it a try
Jogge
Best tip I can provide is download all styles available and have a look at their structure.
Most of the styles only has different CSS and images... this means that you can create a brand new style just by editing the CSS and create few images.
Few styles also have a different header and footer... and only one has a lot of different files because of its different semantic (which is proSilver).
Anyway, let me know in case you need any help.
@MG: I need to take a look at proSilver, maybe I can adapt phpBB2 or phpBB3 really easily thanks to that? That'd be oh-so-amazing. I doubt it, but still!
Hi all
I am just try to get a style going, there are one question i whant to ask
I just whant to changes the header menu to something with buttons
are here some that can give me a tip on how i do that
I have lookt at Rijeka but i can´t figur out that,
  Seems that i have been away from this to long (LOL)
Jogge
Jogge wrote: [View Post]
Hi all
Jogge
what do you need .... are you talking about style Rijeka?
maybe i can help...
Hi Limun
No i am not speaking speciall about Rijeka it´s how it look like
I am just now testing something and i get back later and show you
Look at the images, i whant to have the menu in top in the other menus place (see images)
And i whant to changes the color of the Menu/MainLinks (see images)
The links i can set but there is the login/logout that i will have some help with
One more is that i whant to changes the width in Author field in the forum post
Link to site
Jogge
Filesize: 214.76 KB
Viewed: 310 Time(s)
It seems like you managed how to solve that.
For similar cases I would suggest to use the "Inspect Element" feature that both Chrome and Firefox have.
