Errors by upgrade XS to Icyphoenix 1066
Subject: Errors by upgrade XS to Icyphoenix 1066
I have upgraded on local my phpBBXS 058b with patch 01-014 to icyphoenix 1055, and upgraded on 1066.
I Use PHP Version 5.2.0 and mysql-5.0.18. I will report the errors i Found on admin board, I hope it helps :)
ACP/Generale/Lista Hacks/Mods (on the right frame shows)
Errore durante l'interrogazione della tabella Hack List.
DEBUG MODE
SQL Error : 1406 Data too long for column 'hack_desc' at row 1
REPLACE INTO phpbb_hacks_list (hack_author, hack_author_email, hack_author_website, hack_desc, hack_download_url, hack_name, hack_version, hack_file, hack_file_mtime) VALUES ('R45 (Adam Alkins)', 'phpbb@rasadam.com', 'http://phpbb.rasadam.com', 'This is an admin module for the ACP system. It allows Searching for users based on their username, email address, date registered, usergroup, permission status (mod/admin), post count, userfields (ICQ/Yahoo/Website/Interests/e.t.c.), Language, Last Visit, Timezone, Moderators (of a specific forum), banned users, IP address (used to post), disabled accounts and disabled PM priviliges.', 'http://www.phpbbhacks.com/download/3958', 'Advanced User Search', '1.0.2', './../docs/hl/Advanced User Search.hl', 1135704110)
Line : 120
File : functions_hacks_list.php
ACP/Forum/Gestione (on the right frame shows)
Couldn't update list of Forums
DEBUG MODE
SQL Error : 1406 Data too long for column 'main_type' at row 1
UPDATE phpbb_forums SET main_type='c, cat_id=1' WHERE forum_id=1
Line : 186
File : admin_forums.php
ACP/HomePage/configuratione (on the right frame shows)
Critical Error
Could not query portal config information
DEBUG MODE
SQL Error : 1146 Table 'my_bop.block_variable_table' doesn't exist
SELECT * FROM BLOCK_VARIABLE_TABLE ORDER BY bvid
Line : 49
File : admin_portal.php
ACP/HomePage/Gestione Pagine (on the right frame shows)
Critical Error
Could not query portal config table
DEBUG MODE
SQL Error : 1146 Table 'my_bop.portal_config_table' doesn't exist
SELECT config_value FROM PORTAL_CONFIG_TABLE WHERE config_name = 'default_portal'
Line : 81
File : admin_layout.php
ACP/HomePage/Gestione Blocchi (on the right frame shows)
Could not query layout table
DEBUG MODE
SQL Error : 1146 Table 'my_bop.layout_table' doesn't exist
SELECT lid, name FROM LAYOUT_TABLE ORDER BY lid
Line : 989
File : admin_blocks.php
ACP/HomePage/Tag Posizione Blocchi (on the right frame shows)
Critical Error
Could not query layout information
DEBUG MODE
Line : 261
File : admin_blocks_pos.php
ACP/HomePage/Variabili Blocchi (on the right frame shows)
Critical Error
Could not query blocks variables information
DEBUG MODE
SELECT * FROM BLOCK_VARIABLE_TABLE ORDER BY block, bvid
Line : 338
File : admin_blocks_var.php
ACP/Sicurezza/Proxy&Agent blocker (on the right frame shows)
Critical Error
Could not query CrackerTracker Blacklist information
DEBUG MODE
SQL Error : 1146 Table 'my_bop.ctfilter' doesn't exist
SELECT * FROM CTFILTER ORDER BY 'list' ASC
Line : 76
File : admin_ct_blocker.php
ACP/Sicurezza/Configurazione (on the right frame shows)
Critical Error
Could not query CrackerTracker settings
DEBUG MODE
SQL Error : 1146 Table 'my_bop.ctrack' doesn't exist
SELECT * FROM CTRACK
Line : 48
File : admin_ct_config.php
ACP/Sicurezza/Seleziona footer (on the right frame shows)
Fatal error: Cannot use object of type ct_database as array in C:Inetpubwwwrootxsadmadmin_ct_footer.php on line 95
ACP/Sicurezza/Test di sicurezza (on the right frame shows)
Fatal error: Cannot use object of type ct_database as array in C:Inetpubwwwrootxsadmadmin_ct_seccheck.php on line 95
ACP/Sicurezza/Test di sistema (on the right frame shows)
Fatal error: Cannot use object of type ct_database as array in C:Inetpubwwwrootxsadmadmin_ct_systest.php on line 66
I hope it helps :) I can't do anything else
Subject: Re: Critical Errors In Icyphoenix 1066
Use this steps to update ? :|
Readme
Subject: Re: Errors by upgrade XS to Icyphoenix 1066
Thanks for your hint ;-)
This topic is locked because of the last part of MG 's post:
http://www.icyphoenix.com/viewtopic.php?p=6491#p6491
Generation Time: 0.2781s (PHP: 56% SQL: 44%)
