Post Sudoku Spanish Translation
I translated the Sudoku plugin from English to Spanish.
I will try to translate to SP all the plugins and check all the Icy translations cause I found some things to fix.
A question: Is there any way to use GIT to upload my changes?
trunk.zip
Filename: trunk.zip
Filesize: 4.33 KB
Downloaded: 325 Time(s)
rixardSend private message
Post Re: Sudoku Spanish Translation
Hi, and thanks for the translation(s) !
You need to wait for MG to upload your package to GIT, you can't do that by yourself.
Informpro wrote: [View Post]
Ok, thanks for the answer. I'm learning to use GIT. I don't understand some things yet.
a pull request might do ??
spydie wrote: [View Post]
Hi Spydie,
Yeap, I did a pull correctly. I'm using SourceTree. I tested GitHub for desktop and I don't like it, maybe because I don't know use it.
Hopefully this weekend I'll update it.
Thanks for the translation.
