I'd Like To Edit The Share Buttons Area
Subject: I'd Like To Edit The Share Buttons Area
Hi, friends! It's me again :oops:
I need to share my topics by Google+ but this button is not in the share buttons area. I had to set it through sponsors section, but I don't like how it looks.
8432073634
I was looking for the php file to edit it, but I did not find it.
I've realized that some of the share buttons are not updated, others don't work. Is there some way to modified this area? I'm thinking about removing some of them, and adding the Google+ button.
Is it possible? :roll:
Subject: Re: I'd Like To Edit The Share Buttons Area
If you can tell us which ones need to be updated/added/removed, we can probably do it once and for all :)!
Informpro wrote: [View Post]
Hi, If you can tell us which ones need to be updated/added/removed, we can probably do it once and for all :)!
Thanks, Informpro :mryellow:
Added → Google+
Maybe updated →
  • Delicioussb_delicious
  • Stumbleuponsb_stumbleupon
  • blogmarkssb_blogmarks
  • redditsb_reddit
  • technoratisb_technorati
  • co.mmentssb_comments
  • cgi.farksb_fark
Maybe removed →
  • Netscapesb_netscape
  • newsvinesb_newsvine
  • yahoosb_yahoomyweb
  • bookmarksb_bookmarkit
  • feedmelinkssb_feedmelinks
  • spurlsb_spurl
Thanks for reporting, I think most of them may be just removed... :-)
Hi, God bless you, guys!
Cristianita wrote: [View Post]
I've realized that some of the share buttons are not updated, others don't work mutuelles auto-entrepreneur. Is there some way to modified this area? I'm thinking about removing some of them, and adding the Google+ button.
Maybe they just forgot, but it will be fixed quickly.
I don't think they forgot. Looking at the source code I can clearly see that Google Plus is added. Not sure it is public released yet. I believe it is the version that Luca posted about in the announcements of this forum that the website was upgraded to.
The files are many if you wish to tackle it on your own. It's like 15 files and I believe some database entry as well. I grabbed the file from Github and had a look with Notepad++.
**EDIT**
To be a little more precise, here is my search from Notepad++
Search "googleplus" (49 hits in 16 files of 5141 searched)
Subject: Re:
*Poof!!
Sorry all. I edited my post. It was a spammer alert.
:mricy:
Generation Time: 0.1073s (PHP: 19% SQL: 81%)
