Post HIDE BBCode Customization Question
how can I customize my hide bbcode so that instead of showing a message "Sorry ....you must reply to see this message" it shows the "Thanks" Button that they click on and then they see the message. Thanks
aliks0905Send private message
Post Re: [hide[ Bbcode Customization Question
If you use the beta, it is included.
If you use other version, seach a little bit, there is a topic with that info
I looked around and only found one post that was closed because the guy was begging too much. but no other posts on how to implement the thanks button into the hide bbcode. anyways, I tweaked my bbcode a little. check it out and see if there are any errors
Edited by novice programmer, Thu 01 Nov, 2007 20:56: added spoiler and deleted lines
there you have it http://www.icyphoenix.com/viewtopic.php?f=4&t=1509
jzSend private message
Oh, i forgot telling you shouldn´t put large pieces of code outside a spoiler..
aliks0905 wrote: [View Post]
Has anyone tried this? and please let me know which file and how to edit it?
Thank you a bunch
xmenfileSend private message
that lines are in bbcode.php i posted how to. please search
Zuker wrote: [View Post]
you mean this http://www.icyphoenix.com/viewtopic.php?t=1533?  That's what i have on my IP, but i am looking for the code for user to open by click on "Thanks" button, not "Reply" just like the 1st post said.  Please correct me if iam wrong.
i answer that before.like i told you
Please search, thanks
I found it.  Thank you Zuker.
But I need 1 last modify for this message
Sorry, but you must be registered and also must post a reply to view this message.
I want it to say
registered users must click thanks button to view the hidden message
I have edited bbcb_mg.js, but did not work.  Can anyone show me how to fix it?  I appreciate it.
s_hide_help = 'Hide a text, registered users must click thanks button to view the hidden message: [hide]Hidden Message[/hide]';
PS:  I also created 2 image and want to share them.
Filesize: 6.99 KB
Viewed: 13570 Time(s)
Filesize: 6.52 KB
che en lang_bbcb_mg, i think that lines are there
Post Re: HIDE BBCode Customization Question
Stupid me, i edited wrong file.  it's good now.
Thank you Zuker
