Post Need Help On Rank , Color Group Etc
i create rank from ACP>Users>Ranks
here is my rank pic
myrank
Now the problem is , the rank not show up on a new registered user. I need to manually assign the rank to new user one by one
here is the img about user profile
rank
any way to make the Rank 1 Title set to default as Automatic Ranking by post ?
and Rank 2 title set to No rank assigned ?
carltesSend private message
Post Re: Need Help On Rank
You don't need the first rank to be assigned.
The second rank is parsed as well.
Are you sure that it is not assigned automatically?
May I have a link to your site so I can check?
yup , rank not assigned automatically , and color group too
can't show my site now before this problem solve    http://www.phpBBXS.eu/viewtopic.php?t=648
I think you have some errors in your tables.
When you have your site running again I will check ranks.
hello , my site is up , http://yeahz.net
i register a new user "test2" , but it not auto assign his rank , and the user not assign to color group too
see this thread http://www.icyphoenix.com/viewtopic.php?t=90 , my phpBBXS also upgrade from 049 , assign rank and color group not work anymore after upgrading to 058
still have 1 more problem , gif and png format picture not showing thumnails on album
Post Re: Need Help On Rank , Color Group Etc
any one know what the problem on it ?
For the ranks issue check to see if Automatic Ranking by post / day is active! see pick
Description: rank pick
Filename: Snap1.jpg
Filesize: 40.89 KB
Downloaded: 971 Time(s)
jzSend private message
jz wrote: [View Post]
same option with all but not work
Try to give me admin access via PM and I'll check.
