I'm facing a problem with upload function with FAP, I've tried several things so I hope one of you can help me.
So, I've copied every php files from the archive and modified phpbb php files as mentionned in the install note. So I have the configuration menu within my phpbb config panel. Also, FAP db are created inside my sqldb.
I've created categories within the config panel to class my wow screenshots and have set the permissions to moderator for my group. Everything is ok, I find my categories, go within and click on the upload link, but the function of uploading pictures is not working, I've got always the same error message and I cannot find any reference how to fix it.
Here is the error message:
I check the dates of my files and folder present on the server, but I cannot find any modified files or folders corresponding with the created categories I've created above !
Can someone help me to fix that problem ? I can use OTF Gallery to show my guildies screenshots but I'd rather prefer that they send directly their pictures to the right categories, make me spare a lot of time
Thank you !
Lone Star State
